removing wheel anodizing
I would work with a scotch bright or 1500 sand paper first before using the acid method.
What works is lye. Red Devil (the drain cleaner) was pure lye, but they stopped making it. An Ace Hardware should have lye, though. Depending on how agressive you want to be, create a 2-5% by weight mix of clean water and lye in a bath large enough for the wheel. Let the wheel sit in it and check every five minutes. Do not let it go too long or the lye could start eating the underlying metal.
The anodized layer will turn a powdery white when it is coming off. Remove the wheel and polish about three to four times with something like Mother's aluminum polish (my preferred choice). Each time, you will see more reflection and eventually you will get a mirror shine.
To paint, you first need to degrease because the polish leaves a protective coating. So, use Purple Power/Simple Green/Brand X and a clean sponge to clean the wheel. Then towel it down with a lint-free cloth before painting with Por-15 Glisten PC or Eastwood Diamond Clear. Make sure you use a clear that adheres directly to metal.
The other anternative is to wet sand the anodized layer off: start with 400 grit to get the anodizing off. Then 800 to remove the 400 scratches, 1200 to remove the 800 and then 2000 to remove the 1200. Then polish three to four times, clean with degreaser and paint.
Both of these methods have worked for me, but the lye is way quicker and less destructive.
Matt
Matt
Here's the deal, any large industrial town will have anodizing places - some will deal with an individual. Check with hot rodders or bike guys who have had good luck and go with their advice.
The place I used did hundreds of thousands of parts for Sears. The guy said hard anodize is not UV (ultraviolet) stable and is greenish unless strongly dyed. If dyed black it turns purple eventually. His statements - I don't have experience in this, but it was a pretty big operation.
My wheels are just like factory in that they still stain, except now they're kind of purple!
