DIY Supercharger install...First pic's on 83' 928
I just wanted to post the first pictures of my S/C install. I am mounting it in the location where the A/C was. I just have it Tack welded and will do the final welding and finishing the next couple of days.
Let me know if you guys have any suggestions while I am at this stage.
Thanks,
Oscar
Akron, Ohio
Thanks,
Oscar
Akron, Ohio
The pulley's don't line up yet. I need to weld a spacer to the pulley to bring it out about 1". I am going to run the pressure side up and towards the front on the passengerside of the plate, I need to take about 3" off right past the hole that bols the plate to the A/C bracket and that will be enough room. I used 1/2" plate. A little thick but that was what they used on the S/C when it was made for the Mustang that it came off of.
Oscar
Oscar
