Eaton M112 cheap on ebay!
#46
Originally Posted by docmirror
BTW, this is the same supercharger found on the ford T-bird. They use a different set of pullies, but it's the sam unit. You may be able to find them in a breakers yard.
Doc
Doc
#48
Man of many SIGs
Originally Posted by Rick Carter
IIRC the Thunderbird uses an M90 not M112; the 2003/2004 Cobras use an M112 and are sometimes for sale when they are replaced by a twin screw. The Cobra M112 has the blower inlet on the side and not back like the Jaguar M112.
#49
Originally Posted by Fabio421
I thought this was a twin screw.
Twinscrew BELOW, the ROOTS blowers lobes dont twist. They are straight lobes that simpley inter-mesh.
#50
Heinrich,
Is it going to be possible to make a shopping list of everything you come across needing for this build? I was also wondering if someone would be willing to post a drawing of the intake manifold for the M112. There are some old posts from Andy for the list of things, but since most of his stuff is MIA, I would be interested in what you come up with since you are planning on making it cheaply.
#51
In the Eaton air is trapped in the concave portion of the rotor, moved around the outside of the case to the manifold, and then squeezed out of the rotor cavities when the rotors merge on the way back up at the center, leaving it in the manifold. The trapped air remains atmospheric until it reaches the manifold.
A twin screw has the rotors moving in the opposite direction, compressing the charge between tightly mating rotors as they move down at the center. Compressing the air before the manifold.
Corky Bell explains it better I loaned his book out so this is the best I can do.
#53
Inventor
Vat is your plans, Tovarishch? You vill have it intercooler on this one, or vot?
#56
928 Collector
Yet another victim of UPS, but the damage is apparently fixable at least. Cobalt, thanks for picking it up for me and sending it
I owe you several cold ones
#57
you got to be kidding dude... looks like the ups guy dragged it behind his truck for a couple of miles. did you see him dropping it off? i would have given him s*it....
#59
Under the Lift
It doesn't look particularly well packed, although it did get beat around. The loose peanuts just moved aside. It needed a lot more than a layer of plastic around the unit and some loose peanuts.
#60
Administrator - "Tyson"
That is probably the worst packing job I've seen in a while.
