928 Forum 1978-1995
Sponsored by: 928 Specialists
SOLD ! : Rare Z-box Sub enclosure - SOLD !
Old 01-17-2007, 10:46 AM
SeanR
SeanR's Avatar
It's a shame that it will only do 8" subs.
Old 01-17-2007, 01:12 PM
fabric
fabric's Avatar
Originally Posted by alpinadvl
I am purposely "reserving my "bumps" for a later time" so will use this opportunity to answer this.....
--> this unit is not made to be bolted into place or glued into place.
It is a perfect pressure fit (look at all the contours and edges...its really perfect!)
. Also if you look carefull the bottom edge has space, and does not fully cover the bottom of the trunk...I believe this is so it is possible to remove the carpet with the box still in place....
I can't see the rear tie down straps, so this is covering several inches of carpet I suspect. If you have the carpet attached correctly, there is no way to get the carpet unhooked without removing this thing. You probably can lift it easily and get the carpet on that side unhooked, so it's not like you can't get at it without tools, but I was simply responding to another poster who said you could get at the spare without *moving* the box at all. This is clearly not possible.
Old 01-17-2007, 01:27 PM
123quattro
123quattro's Avatar
I had one in my car. I could take pictures of it this weekend if someone would like to see one installed.
Old 01-17-2007, 10:55 PM
F4GIB
F4GIB's Avatar
I'll take it. PM sent.
Old 01-19-2007, 01:51 AM
alpinadvl
alpinadvl's Avatar
SOLD !
Quick Reply: SOLD ! : Rare Z-box Sub enclosure - SOLD !
