Pics of degree wheel and hub. (Dialup, grab a brew)
Rest in Peace
I have been wondering how accurate the indicator on the crank hub is, now I know that it is off by a degree or two.
Everything will get cleaned and painted or powdercoated before it goes back together.
Here is the dial indicator for finding TDC.
The degree wheel
The hub at TDC, you may not be able to tell from the pics, but it is off by a couple of degrees.
I really need to clean the shop up, maybe tomorrow.
Here is the project 928, it is getting ready to go to the body shop the first of next week, I have to pull the door panels, mirrors, front and back covers, ETC.
I hope every one has a great weekend.
Greg Nettles
![](http://i57.photobucket.com/albums/g239/ac4vette/onstand/dialindicator1.jpg)
The degree wheel
![](http://i57.photobucket.com/albums/g239/ac4vette/onstand/degreewheel1.jpg)
![](http://i57.photobucket.com/albums/g239/ac4vette/onstand/hub1.jpg)
![](http://i57.photobucket.com/albums/g239/ac4vette/onstand/onstand1.jpg)
![](http://i57.photobucket.com/albums/g239/ac4vette/onstand/prepaint.jpg)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Greg Nettles
A dial indicator is very accurate, for exact TDC the piston stop method is exact. Degree wheels are not always perfect either. You can check a degree wheel by laying it flat on a piece of cardboard. Make a mark every 90 degrees. If the wheel is on the marks will line up as you rotate.
Received 1,617 Likes
There's probably enough 'wiggle' in the screwed-to-the-water-pump indicator to make it a +/- 1 degree indicator. Looks like it's off by about one degree.
Rest in Peace
There was only a couple of degrees with no piston movment. Some of the motors I have done have had a bunch of "null".
Rest in Peace
Originally Posted by Bill Ball
I saw the comment that the crank TDC mark can be off 4 degrees. How does this happen? Is the balancer two-piece?
Rest in Peace
I had never thought of checking it, hmmm, maybe I better do that.
Rest in Peace
Piston stop can be done with heads on.
I just normally do it with the heads off, and check the crank to make sure there is nothing off there between cylinders.
Rest in Peace
One from cam dynamics.
I just really want to see how far off the cams were, anybody out there got a Porken 32 valve tool?
Originally Posted by blown 87
Damn, was it a pro one or a small one?
Rest in Peace
Originally Posted by Mike Simard
Do they make degree wheels any bigger than that? Just think how accurate that would be!
