WTB Clutch stuff and TB/WP
Rest in Peace
Greets 928'ers,
I need to buy (new or rebuilt) '81 Clutch master and slave cylinders and clutch hose set. Does anyone have these goodies?
Also a complete setup for TB/WP goodies for my TB/WP party coming soon, to Bill Ball's place (pretty please).
Cheers,
Cheers,
Under the Lift
Sure, late in the month or early Feb.
Any of our prefered 928 vendors will put together the TB/WP goody pack for you, as well as get you the other parts you are requesting.
Somebody on the list PMed me about a clutch after mine was already in the works, if you don't hear from them I could check my old PMs. My slave should be "ok", but a new one was like $75 vs $20 for a rebuild kit I think.
I strongly recommend that you NOT use a used clutch master cylinder because it is very difficult to change and a good one may have developed a rust ring at the bottom of it's bore so when you start bleeding the sysytem moving the pedal it THEN hits the rust and ruins the master cylinder seals . I missed a drivers ED weekend when my master cylinder decided to fail as I was bleeding the clutch system late on a Friday night...Also had a clutch hose blow at the track one weekend lost part of that day made a night run to 928 (second car)and installed the hose early on Sunday. Obviously I have all the parts you might need .
