Question Regarding Exhaust Manifolds
Man of many SIGs
Will the 85-86 manifolds fit a 16v car?
Is it possible to "flip" the manifolds around so that the outlet flange is in the front instead of the rear? Basicly you would put the left manifold on the right side and vice versa. This question goes for both the 16v and early 32v manifolds.
Yes, they "will fit" but they don't just "bolt on". You have to enlarge some holes, remove some heat sheilds, and extend the Y pipe on the right side (for use in the conventional orientation). On my car ('81), the right side motor mount support bracket had to be modified as it was rubbing on the manifold bellows.
As far as reversing... I have no idea.
Man of many SIGs
Is the bolt pattern symetrical? I am mainly interested in flipping them to the front. Maybe an way to ask this is:
Does this photograph depict an early 32v exhaust manifold or a purpose built manifold.
Thanks.
Thanks.
That looks like the early cast design manifold to me, but there is something funky going on at the bottom where it would hook to the cat. The webs between the downtubes is a sign to me that it is the older cast design and not the early 32v tubular.
Man of many SIGs
Thanks Byrdman.
OK. I found a pic of the 85-86 manifold. Can anyone confirm that the pic shown attached to the engine is indeed a 16v manifold and whether or not it has been modified?
This picture is provided courtesy of www.928intl.com
Here is a pic from ebay. I think they are definitely early cast manifolds, but the bottom portion has been modified so that it turns straight down instead of angled.
Administrator - "Tyson"
IIRC those who have flipped them around melted the timing belt.
Man of many SIGs
The reason I am asking this is that I am trying to figure out what I will need to get started on a twin turbo project. I have seen a home made twin turbo 928 recently and I have also been doing alot of research as to what is involved in making this happen. Top that off with aquiring an 8.5:1 compression ratio 4.5L and I now am more eager than ever to try it. I believe it can be done at a reasonable cost with minimal plumbing. I was hoping that I may be able to mount the exhaust manifolds backwards and build from there. I plan on mounting the turbo's low and forward. I have two plans for intercoolers. Both involve air/air I/C's the only difference is location and quantity.
I hope John is progressing along with his S4 project.
Man of many SIGs
Originally Posted by toofast928
Ok I give up. Why flip the exhaust manifold and have it exit the front of the engine.
Marine application?
Marine application?
The 16v manifolds look to be cast and the 85-86 32v manifolds appear to be fabricated. Is this correct? If so I may have to use the 85-86 manifolds for durability. I'm not sure how well I could get the cast manifolds to hold together at the welded joint, even using a hi Ni content filler. It looks like both styles of manifold will have to be modified to get a vertical orientation (<30 degrees) of the turbo's. This should also allow the turbo's to be mounted slightly above sump level and therefore eliminate the need for an oil scavenge pump.
Basic Sponsor
85/86 are fabricated and the pre 85 are cast as the eBay pic shows.
IIRC the 85/86 fit on the 16v cars but not the post 86 ones allthough they look similar.
Roger
Roger
