928 Forum 1978-1995
Sponsored by: 928 Specialists
Broken hose under front right wheel well - what is it?
Old 12-29-2006, 02:05 PM
0utlier
0utlier's Avatar
Default Broken hose under front right wheel well - what is it?
I had the car on a lift at my mechanics place to pull the side markers and we found this hose broken when we took off the wheel well liner. What is it? Thanks.
Old 12-29-2006, 02:10 PM
macreel
macreel's Avatar
Outlier... that's the infamous plastic "Y" connector in the fuel
vapor plumbing.
See Nicole, at Hooked on Cars.
G'luck.
Old 12-29-2006, 02:11 PM
deliriousga
deliriousga's Avatar
Yes, get the Stainless replacement from her. It's a fantastic, never do it again fix.
Btw, that's the hose that goes to the charcoal canister to absorb gas fumes. If it's broken, you'll get the wonderful smell of gasoline filling the local air.
Old 12-29-2006, 02:12 PM
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
The old famous plastic Y connector to the vapor cannister. These ALWAYS break. Nicole at www.Hookedoncars.com has a very elegant and permanent solution to this problem. Check her site or contact her about it. You are probably getting some nice gasoline fumes down there as well.
Old 12-29-2006, 02:14 PM
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
I type too slow!!
Old 12-29-2006, 02:26 PM
0utlier
0utlier's Avatar
I've never noticed a gas smell in the car. Strange. Thanks for the info.
Old 12-29-2006, 02:39 PM
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
Mine was broken and I never smelt any gas odor in the car either. BTW, take the broken piece(s) to your local hardware store.... That was my solution, I think it cost all of 67 cents.
Old 12-29-2006, 02:49 PM
MGW-Fla
MGW-Fla's Avatar
I know Nicole sells the Y fitting, but I don't seem to be able to locate it on her web site??
Old 12-29-2006, 03:41 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
They are ALWAYS broken. Here's mine before the SS replacement.
Old 12-29-2006, 05:44 PM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
That's because I just sold my last one, and the online store software takes the listing off when inventory is depleated. I'll try to get more and post here when I have them again. I had not sold one of those in about 6 months, so I let it slide... sorry for that!
PM me, if you want one - then I have a better idea of how many we'll need.
Old 01-07-2007, 08:41 AM
Nicole
Nicole's Avatar
The stainless Y-Connectors are in stock again here:
http://www.marketworks.com/StoreFron...39&i=120485666
Old 03-12-2024, 12:51 AM
928Collector
928Collector's Avatar
Default Front Passenger Wheel Well hoses?
Can anyone help with these hoses?
Diameters?
Are there PSI requirements?
the blue arrrow is an 8AN 1/2 inch diameter braided stainless steel high pressure hose for oil fuel.
Any help / guidance on any of the other hoses much appreciated as I'll need to replace them.
(please note photo below is not an actual photo of my 1980 passenger wheel well)
Miles928 (03-14-2024)
Old 03-12-2024, 02:05 AM
The Forgotten On
The Forgotten On's Avatar
^^ The hoses have no real pressure in them. They're just vent lines.
If anything they could carry vacuum. You just need to make sure they're fuel rated.
Old 03-12-2024, 02:10 PM
Zirconocene
Zirconocene's Avatar
Here's an overengineered solution:
AN Y Block: https://www.racetronix.biz/p/y-block...ck/yblk-900606
Female AN to hose barb: https://www.racetronix.biz/p/adapter...ack/adf-6jfb38
You might have to play with the options to get the hose barb sizes right.
ETA: Here's a much cheaper solution, but you only get one hose barb size, though it's at least in metric:
Amazon Amazon
Cheers
Old 03-13-2024, 10:41 PM
buccicone
buccicone's Avatar
ETA: Here's a much cheaper solution, but you only get one hose barb size, though it's at least in metric: https://www.amazon.com/Pangyoo-PYouo...093P5JT3R?th=1
Cheers
The only problem is the hose sizes are different.
Quick Reply: Broken hose under front right wheel well - what is it?
