Why did Porsche opt for a timing belt vs. chain?
#61
Originally Posted by Hacker-Pschorr
Friend of mine started taking his ZO6 track car to work (410+rwhp) to save money over driving his Yukon every day.
Heh. If you are doing lots of highway miles, the Corvettes are pretty good fuel economy-wise, but even around town are pretty reasonable, considering. The Z06 has about the same ratings as my BMW V8, a bit better on the highway.
On a total thread drift note, my friend just sent me the ebay listing for an E55 wagon, and they had a shot of the dash showing fuel economy - 11.4 mpg.
#62
On a total thread drift note, my friend just sent me the ebay listing for an E55 wagon, and they had a shot of the dash showing fuel economy - 11.4 mpg.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
#63
I have had 3 timing chains jump teeth on non-interference engines. Each time it was in the driveway at home. Car would not start - check ignition timing (distributor technology) to find it was out by 25 degrees.
My wife used to drive a 1987 Toyota Supra Turbo. It had belt driven cams and showed no wear after 60,000 miles service intervals although I did the change anyway.
Now she has a Subaru, also belt driven cams (4), oil pump and water pump - sound familiar? The difference here is that a new belt has 5 white marks that you just align with the marks on the crank gear and the 4 camshaft gears - timing is done. Of course, it also has a "Porken" hydraulic tensioner factory installed!
Any moving part is subject to failure over time, just a question of when.
Brian.
Brian.
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
#64
HTML Code:
and Porsches instead of spending another $50,000 to drive a truck...
Marton
#65
Has anybody ever looked into what it would take to make a non-interference 32 valve engine ? Is it possible ? This would really make any weakness in the design moot. Not that it would be practical to retrofit unless rebuilding/swapping pistons.
#66
I would change the belt often and not worry about it
#68
Originally Posted by 123
I've seen broken chains as well as belts. Kind of surprised that there hasn't been more mention of gears. Okay, I guess I can see why that may be.
