928 Forum 1978-1995
Sponsored by: 928 Specialists
Timing an 87
Old Dec 27, 2006 | 11:24 PM
Kevin Michael's Avatar
Kevin Michael
Rocket Pilot
Default Timing an 87
Does anyone know what my timing should read at idle on the 87s4?? I want to put the strobe on it but need a spec to start with so I am not guessing. I know it's not adjustable, but curious to check. Any quick checks for the hall sender as well?
Thanks,
Kevin
Old Dec 28, 2006 | 04:12 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
It's 10 +/-2 degrees BTDC at idle. If the Hall sensor is bad it will be retarded 6 degrees, but only on moderate load/WOT. So, instead of 32 +/- 4 degrees above 3k RPM, you would see 26 or so.
Old Dec 28, 2006 | 02:48 PM
Kevin Michael
Rocket Pilot
Bill, Thanks! It seems you always have a willing to help attitude!
Kevin
Old Dec 28, 2006 | 04:54 PM
RyanPerrella's Avatar
RyanPerrella
that attitude combined with his knowledge, and you cant go wrong.
Rock on!
