Why the split in wheel size front to back on newer 928's?
if you have "twitchy" issues with a 8" rim and wider rubber in the 255range, you have alignment issues. actually the wider tire makes things quite stable. when i put my 305s and 275s on the holbert car before the conversion, it drove like a dream. very stable over all surfaces, however, the sidewall stifness was a little harsh for a street car.
i went for a 225 and 245x50 rear mix on the 7s to get a little more meat in the rear. then, with the 7.5s and 9s, i did 235x45, 245x45 front and 255 to 275 rears. so ive pretty much tested them all. and on a street car (cup rims by the way) it was better each time i went larger. no trade offs. actually, the skinny tires just didnt do the platform justice. it pushed, had a more unstable ride and over all the larger tires no matter how i did it, always came through a positive.
mk
mk
Originally Posted by jon928se
I forget the early 928s (78,79) with 15" comfort fit wheels but didn't all 928s have 7" front and 8" rear until the SE/CS/89GT which had 8" front 9" rear then the 90GTon and GTS had 7.5" front and 9"rear.
Reason why factory stayed in so narrow wheels and rubber was that original design didn't allow any wider. They have to be certain that all possible tire brands of selected size will fit without problems and have some margin to spare. Now people are using all margins and then some to fit 275 at front and 315 at rear etc. Factory can't do tight fits like that on production vehicle. Besided so wide street rubber wasn't even readily available when 928 was designed.
Inventor
Snow chains too!
BTW, any idea why there were 'winter' rims? Was there some thought behind the shape of the rim?
Originally Posted by PorKen
Snow chains too!
Wide tires and wet weather can be a real handful for most drivers. Fortunately my 60/40 Mustang has me trained to drive like granny if somebody spits.
This one, BTW that site gives me errors directly, I search it via google.
Wheel - Factory "Design 90" Front 16x7
928.362.154.05
Price: $545.00
Too many digits.
928.362.154.05
Price: $545.00
Too many digits.
Look for the Cup Racer set. Not suggesting you buy them, but look at the 17 x 9.5 size, and the 255 series tires fitted by the factory. Once you have ridden in a wide tire car it is hard to go back.
Big wheels make me think of covered wagons, I like what sidewalls do for me.
What I will be watching for are a couple of somebody's 16x(whatever is one bigger than mine) take offs, expecting to get two nice wheels with decent 245 ish tires for maybe $300 if I am patient. Its not like old 16 inch 928 wheels are in great demand. Polished and/or chromed preferred maybe buy a whole set if staggered or 235 would work in the front on them.
Originally Posted by perrys4
Sounds like a guy trying to learn more about his car, very interesting and legitimate question. Wheres the problem?
You're right, this was one of danglerb's more reasonable questions, no need for me to have been snippy.
