No low beams 79 euro
I didnt have time to really dig into it tonight. But i have no low beams.
On my fender next to the rad it two cylinder looking things with wires attached at either end, One was to hot to touch, what are they?
A corroded connector could cause a dimming of the lights and a hot connector, but no lights? My guess would be a bad connection at the hi/lo headlight relay, bad hi/lo relay or bad switch at the steering column. The switch can be checked at the relay connection. There should be alternating 12 volts at the 85 and 86 connections as the switch is changed from lo to high beams. If the relay itself is bad, some modifications will be required unless you can find a used one. New ones have been NLA for quite a few years.
Dennis
Dennis
Those ceramic cylinders are the resistors for the coil. They drop the 12 volts down to keep from overheating the coil.... On cranking on the starter it only uses one for a hotter spark normal running the power flows through both. For BOTH lights to not have power it has to be a switch or relay problem .....
Originally Posted by Jim bailey - 928 International
After 14 years or so having customers describe parts over the phone....sometimes you get lucky
Thanks, Ill look into a fuse and relay tonight
I hear the relay click but the lights dont come on. I bet i fried the relay yesterday when i plugged it into the fuel pump socket, it sure did make a hell of a racquet. will that relay fit the FP socket? Ill have to pull the relay open and see whats up. I have to go look at teh fuse charts and see what exactly i plugged in wrong
The fuel pump relay requires a pulsed tach signal(straight off the ignition box) to stay energized. This is essentially AC current as far as the relay is concerned, and will make the contacts vibrate at 4x engine RPM, causing them to arc severely. You may have burned the contacts in whatever relay you put in there. Beware -- advice that works for later cars(e.g. swap the horn relay into the FP relay socket) is not always valid for 78/79! OB FP relays should only be checked by either jumpering the switched terminals or swapping in the correct relay. Another example of a relay that uses the tach signal on your car is the AC speed relay.
You may be able to temporarily bring the headlight relay back to life by taking it apart and cleaning the contacts, but that won't last long -- there is a thin, hard plating on the contact surface(usually a nickel alloy) and once that's gone the underlying soft metal(usually brass or bronze) will erode very quickly. If the contacts don't look burnt don't use an abrasive on them -- I prefer a business card squeezed between the contacts to clean them(old trick from when cars used to have points).
