The trailer lamp should not light up and I do not know what servo is for. My car does not have the AC or lock button so I have not run into that. You will have to find the source at the central warning system and check for continuity at the other end of the wires.
That would have been VERY helpful, but on my 86.5 the RED LINE is where the "CERVO ( / )" which has a ICON that looks like a circle with a twist next to it and the GREEN LINE is where the TRAILER FLASHERS are.
The only reference to a CERVO I find is the Cruise Control Cervo. I found it on the Wire Drawing in the WSM. But it doesn't light when tested.
Originally Posted by Majestic Moose
Oops I thought it was in here. See attached.
The snarkiness in my post was unintentional. With >3K posts I have at least 2 or 3 times asked a question I could have found the answer to by searching...
Wasn't taken that way by me....I just snap responded, it was helpful someone added to the conversation who had the time to look for an answer. Thanks again...was good intel.
