High NO - Is this a cause? UPDATE - Nope.
#32
Under the Lift
Originally Posted by perrys4
Your wife must really love you letting you buy all this cool stuff.
#33
Chronic Tool Dropper
You can sometimes find good deals on apparently-good analyzers. I had a good one (Sun) that I used for years, until it came time to start replacing detector modules. $$Ouch!!$$ So it went away, and hasn't been replaced. There are more durable designs these days that don't need quite the same level of care that my old one did, but they are a little steep to just have hanging around.
The guy who does my smog volunteered to do the test with the trans held in second gear on the auto, and it passed NOx easily. Car guy, former 928 owner, businessman.
#35
The emissions testing that we have is not as strict as yours. I guess replacing everything is one approach. If it passes you just dont know what fixed it, or what you did not need to spend.
#36
Would a dirty injector cause this?
Have any of you guys tried using a infrared temperature thing, look for a hot or cold spot on the exhaust manifold maybe. I picked up the cheap one at HF for $10, but its too limited in temp range, maybe the deluxe $39 one.
#37
#38
Fleet of Foot
My money, unfortunately, is on the cats. Mid-beds on these seem to deactivate long before the rest of it. Considering his are original I would concentrate there.
#39
Under the Lift
Nice idea about the temp of the headers. I do have an one of the IR readers and could have checked that.
Bill - I'm sure he'll end up with a new cat. The car has far less miles than my 89, but we all know my 89 is almost invincible.
#40
BTW HF sells a basic tire change rig doesn't it?
I use my $10 IR temp thing for all sorts of stuff, works for radiator hoses, AC vents, PC heatsinks, restaurant buffets. Some cheap video cams also support an IR mode, so a hot/cold spot might show up.
/flame suit on/ How about calling up CARB, give them the license number and asking if they have any suggestions once the tech pulls up your smog test. 800 242-4450
#42
I've never been convinced that age of cats is as detrimental as having suffered an event, such as a slug of raw fuel, etc: having said that, a used set may be perfectly good and would make for a much cheaper trial .... say a set available from one of the graduates to X-pipe systems ....
#43
Rest in Peace
Originally Posted by Bill Ball
I believe that DEVEK works with a smog shop that will give them assistance troubleshooting the cause. Jeez, it would be nice to have a gas analyzer. eBay, here I come!
#44
Rest in Peace
#45
Received 1,648 Likes
Originally Posted by blown 87
I have 4 gas one that we never use, they are not as handy as you might think, unless you have a dyno to go with it.
