Wheels rubbing on the inside - need advice
Supercharged
Well ****! Need some advice here.
If you will recall in my thread about the new shoes "Finally getting some new shoes!" I just got some Carrera III wheels for my GT.
Fronts: 8x18ET57
Rears: 11x18ET51
I finally got around to trying one of the rears. I'm very happy that it looks like I don't have to roll/flare the rears at all, but it is tight! The issue is the inside - it's rubbing on the fender liner, but not too much.
So here's my dilema. I don't see anyway to pull the liner in any further, so do I let it wear in, or do I cut the offending section out?
Pics.
Fronts: 8x18ET57
Rears: 11x18ET51
Pics.
Supercharged
Originally Posted by Andre Hedrick
Get som AIR shocks or Sky Jacker from the 4x4 forum.
Go for that '64 Nova II look
Another thought is to get a very thin spacer 5mm-10mm and then flare the fender just a bit.
Craic Head
Andrew,
Wow that's tight. Are you sure you don't have to roll the fenders at all? If it's that tight with the shocks at normal ride height, it's got to slam when you hit a bump, no?
Supercharged
To be truthful, I have bot drive it with the wheels on, but pushing down on the rear corner suggests that they don't rub. That said, I think it would be safer to have a bit more room just in case.
Rest in Peace
Originally Posted by Andrew Olson
Sorry I don't speak truck!
Do you want the name?
Supercharged
There is a guy in FL that does custom spacers, I have 3mm in my front.
Rest in Peace
Yes please. I just saw some 3mm spacers on ebay from Ernie's Alloys for $60. Can he do better than that?
Captain Obvious
Super User
Super User
Can you take the fendre liners out? Some of the early 928s never had rear fender liners. Withlout it you might be OK.
I can see that you are going "wider" for traction. Should consider the aspect ratio too. You need some to maintian traction, otherwise the width makes no difference.
