928 Forum 1978-1995
Sponsored by: 928 Specialists
Lube for rubber suspension bushings
Old 12-01-2006, 02:55 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Default Lube for rubber suspension bushings
I am replacing most of the rear suspension bushings. The WSM calls for an obsolete lube. I don't have the WSM in front of me and can't remember the exact name, but I recall it being described as "wax-free". I understand not to use pertoleum-based lubes. I searched the Web for "rubber bushing lubricant" and couldn't find much other than Monroe saying to use a silicone-based or tire lubricant on suspension bushings.
Any other suggestions?
Old 12-01-2006, 03:07 PM
bkingdon
bkingdon's Avatar
How about the lube used for brake sliders.
Brian.
Old 12-01-2006, 03:15 PM
danglerb
danglerb's Avatar
Maybe LPS or this goop from energy suspensions a teflon grease http://store.summitracing.com/partde...rt=ens-9-11108
Graphite, my local electronics shop had a few different tubes of dry lubricants.
Old 12-01-2006, 03:22 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Bill,
Are the new bushings rubber? Because the ones I just got for the a-arms from 928 motorsports are urethane and I think you can use petroleum based lubes on them, no?
danglerb
danglerb's Avatar
or this
http://www.super-lube.com/pdf/msds_S...rease_PTFE.pdf
Bill Ball
Under the Lift
Bill Ball's Avatar
These are the rear bushings - rubber.
Old 12-01-2006, 03:24 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Says it is for polyurethane bushings.
Old 12-01-2006, 03:26 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Sorry Bill, it wasn't clear enough in the title of the thread.
Old 12-01-2006, 03:30 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
I wonder about this - silicone grease "when petroleum grease is not desirable."
http://www.rtxs.com/xcart/customer/p...a857bd2ae6666b
Old 12-01-2006, 03:37 PM
Ketchmi
Ketchmi's Avatar
Hey Bill, Dow 111 is what we use, it's silicone based and safe for rubber. It's main use is for O-ring lubricant but it works well for any rubber application. Well, almost any rubber application that is...
http://www.dowcorning.com/content/ne...p?DCWS=&DCWSS=
Old 12-01-2006, 03:42 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
OK, it looks like slicone grease is it. Thanks Dave and everybody else.
Old 12-01-2006, 05:14 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Looking around for the lube, I found it for sale for about $5 an ounce, then I found this....
BORG WARNER CT543 Silicone Grease: 1 pound for $0.36.
Sure.
But then here's another for $1.59 a pound.
http://www.amazon.com/Mobile-Mart-Pl...7?ie=UTF8&s=hi
Oh, that's the shipping weight. The latter one looks like 1/2 ounce. Still, not bad.
Old 12-01-2006, 05:25 PM
danglerb
danglerb's Avatar
Silicone grease is what I think heatsink compound is made out of or from. Let us know how it turns out.
Old 12-01-2006, 05:44 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Right, I saw some silicone heatsink compound/grease, but some have silver or some other stuff in them. I think the plumber's silicone grease with no petroleum is probably fine.
Old 12-01-2006, 05:55 PM
Flott Leben
Flott Leben's Avatar
Out of curiosity, what does normal grease do to rubber? Eat away at it, weaken it, cause it to lose elasticity?
How about molybdenum grease?
Quick Reply: Lube for rubber suspension bushings
