Wanted: 5 gear for 89 GT transaxle
PSD in '89 gearbox?
I did the same with a -89GT box in my -81S and no need for any modification.
link to thread with pictures of the swap.
5sp gearbox change
/Peter
It had full PSD installed and it was really '89 GT and not early '90 MY first registered late '89 calendar year?
Please do check year code from gearbox number when you have a chance.
Archive Gatekeeper
Below is a shot of my tranny from my '90, VIN # 278, with a date of Jan 10, 1990 on the doorjamb VIN sticker. Is the '3L' the date code? In American muscle cars, a '3L' would be December 3, but somehow I doubt Detroit and Stuttgart use the same coding schemes.
Thanks guys:
You guys are correct I am planning on having to change the TT but I am not sure if I am going to have to change the bell housing as well, anyone know?
What I am looking at should be the 89GT box it has LSD not PSD and it has been presented as such and I was told when I am off looking for the 5th gear to be sure to get the one for the 89GT so I am pretty sure it is one. Since I have such an old car I don’t think any of the PSD boxes will work. From my time thinking about this project I thought the 89GT box would be the best match for my car.
Apparently it is the main 33:22 drive gear that is bad and the box was in the process of a rebuild but the project was put on the shelf, about the only main part still needed is the 5th gear main drive.
The current LSD is good but is the original 79, actually the box is not too bad if you are just putting around but if you want to drive with a purpose second is no friend at all and third can get very notchy.
I’ve owned my car for over 20 years and am looking to revitalize the car and have something I will enjoy driving for another 20 years which is why I am thinking to go with this newer box. I also plan on some pretty good engine upgrades and I think the 89GT box will hold up to them much better.
Thanks,
Gary
Thanks,
Gary
You shouldn't have to change anything up front. Don't think there was any change in the torque tube mounting to the bell, just the length. Jim B. could confirm.
The early upper bell housing is dimensionally the same with various small changes like the size of the ball stud hole, added timing sensor for test purposes. 5spd and auto are the same however only for two disc clutches the 87> auto and 5 speed are different.
Changes were done in different years and there is sort of continuation in modifications where one part is changed and it works with both new and old version ot other part. This means all different upper bellhousings and torque tubes should work with each other.
Code:
123456789ABCDE G2855 3L 00919 1 = Gearbox type, G = manual gearbox 23 = Car model, 28 = 928 45 = More precice type, 55 = GT 7 = Differntial type 1 = open diff (M219) 2 = ZF 40% LSD (M220) 3 = PSD (M221) 8 = Model year, same as 10th digit in VIN, L = 1990 ABCDE = Serial number within year and gearbox type first normal box in '90 and '91 was 00501 00001...00100 was reserved for testing 00301...00400 was reserved for special boxes
Archive Gatekeeper
Erkka-
Thanks for the decoding!
-Rob
-Rob
So basically, the TT length was dictated by the trans case length. The 78-~80 trans cases were 10mm longer? SO the TT was that much shorter. And the later transmissions were all the same length then (5spd), at least the case length, and the TT was 10mm longer for those years?
DO I have this right? Are there any other dimensional changes on the cases of the 5spds? Width?
Thanks for the information.
So a new TT and I should be in business with the new box. It will be nice to not have to buy ANOTHER piece for the project.
Thanks,
Gary
Thanks,
Gary
