Engine detail including intake and cam cover refinishing
Archive Gatekeeper
I'm in-
Bob-
When are you pulling your intake? I'd like to pull mine apart before the kiddo is born, get it media blasted and degreased (boiled out?), replace the flappy bearing, then hit it with the wurth silver and clear. Maybe we can get a bunch o' Socal S4 folks to go in together. Any thoughts on local shops that might safely media blast magnesium? The PO had the valve covers done, so I don't have to touch them (unless of course the Wurth silver doesn't match......)
The Lady's Man
I really need to figure out how to get larger photos with higher res.
Here are the shots of my engine after the Chuck treatment. My coating was all flaked off and all that remained was the grey primer coat. Took about a week of evenings. Lettering was done using testors paint pens.
Originally Posted by Bill Ball
Amazing. I can't believe the masking effort. After looking at your masking and part removal, it would have been easier to just remove the intake manifold. The only other parts you needed to remove were the fuel rails. The whole manifold removal is less than an hour, and almost zero masking would have been needed. The valve covers are relatively simple to expose and mask, so I can see doing them in-place, as you did.
What that hey. The results speak for themselves. Nice job., as always!
Originally Posted by ROG100
The paint holds up very well as the temperatures never get near the paint operating temperature. Look at the paint on calipers - if it deteriates its the brake dust doing it not the extremes of temperature.
Originally Posted by dr bob
My original bolts still have that yellow class-5 cad or yellow zinc plating on the heads. After some of the horror stories about those bolts, I'm tempted to do what you did, but mask the bolt heads. Getting new ones the right color is a chore, since the OEM bits aren't as yellow as the originals are. Pulling the bolts risks damaging the heads, and polishing paint off of them risks the plating.
Did you use any clear-coat over the silver?
Several commented on the before pictures and how clean it looked before I started. The pictures of the before shots make it look cleaner than it actually was and the after pictures do not look as good as it does in person. A car dealer's detail guy got a hold of it (probably why the original finish was peach colored) and sprayed it with that sticky shinny stuff. It collects dust and is really difficult to get off, I removed most of it.
Very nice job Chuck, looks awesome. The finish on the hoses and plastics looks great too, what did you end up using on these?
One of these days I got to do mine
Nice job, Eventually I'll do mine. I will remove mine to replace a minor leak in bridge o-ring gasket. Can you post a list of all the materials you used, required quantities (or minimum they are sold in) and vendor details or links?
94 GTS
94 GTS
Originally Posted by Herman K
Nice job, Eventually I'll do mine. I will remove mine to replace a minor leak in bridge o-ring gasket. Can you post a list of all the materials you used, required quantities (or minimum they are sold in) and vendor details or links?94 GTS
[edit] here is the paint I used: http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Thanks Chuck
I need to come and see your work one of these days, also have some hammer issues (PC programming) to work on with Roger. I'll try and find some time after I return from an oversees trip on December the 8th. Wish I could make the event at Rogers place on the 9th but I have a friend fly in from Europe that same day... oh well. Car is driving great just the lack the time to to do all the fancy stuff you guys are doing. I enjoyed sharing your work. I wish you well.
94 GTS
94 GTS
Hi Chuck,
How is the paint job holding up after a couple years... does it still look good?
I'm contemplating this versus powder coating. For sure my intake is coming off, but if I go this way, the cam covers could stay on.
Has anybody else around hear tried the painting route and still happy with the results a couple years later?
I’d be happy if my end result looks as good as what Chuck had at the start.
I’ve been reviewing a ton of threads on this subject and all few seem to be leaning towards powder coating. I like the idea of using the crinkle finish on the cam covers to help mask the imperfection. I not to thrilled about using in on the intake though… just doesn’t look right to me.
It all really depends on prep work done, and materials used, as is the same with everything.
If you go the powdercoating route, make sure you have them outgas your items a few times!
Team Owner
I would guess that the paint is probably in good condition however the surface that was painted may peel off as it seems that all of the powder coated parts on the intake and to a lesser degree the cam covers all peel off over time
I have not seen as big a problem with the peeling of the finish on the GTS's as on the S4's, could just be age or mile related adn GTS's have that ALL OVER most S4's, so it may just be a matter of time. I am waiting for the rest of the finish to peel off my S4's intake system so I can do the same to it! LOL!
