928 Forum 1978-1995
Sponsored by: 928 Specialists
Does your 928 Burn Oil?
Old 11-24-2006, 03:25 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I beleive the owners manual states thst 1L/5000km is considered normal.
Old 11-24-2006, 04:41 PM
tv
tv's Avatar
Mine burns a little bit, but i think that has to do with high rpm runs.
Black soot could be a rich running deal and maybe not complete burn in a particular cylinder. But that is excessive. Maybe you could talk to the NE Shane as his gts engined 928 appeared to be giving off some smoke.
Old 11-24-2006, 05:53 PM
the flyin' scotsman
the flyin' scotsman's Avatar
Then I can live with 1 litre/7-8k km. I can comment though it does 'seem' to burn more if I go through 2 -3 tanks of gas with very spirited driving. An old friends father was an engineer for Rolls Royce and told stories of taking engines apart to find out why it wasn't burning enough oil.
To the specific question asked; seems rather much oil consumption............have you checked your spark plugs for 'wet' condition?
Also, the black spitting from the exhaust is an over rich fuel condition...................check air filter, MAF etc etc.
goodspeed928
goodspeed928's Avatar
I go thru 1/4 gt, 2000mi
I DRIVE HARD!
6000 RPM Ever time out
Old 11-24-2006, 06:49 PM
danglerb
danglerb's Avatar
Oil has 4 ways to go out;
A drip
Crankcase vent
rings
valves.
Different places likely annoy different people. Drips I have to fix, the vent I would "want" to fix, rings and valves fall into the big picture long term repair plan.
Old 11-24-2006, 07:05 PM
morganabowen
morganabowen's Avatar
I use Mobil 1 15/50, and change the oil every four to five thousand miles. It is usually somewhere a half quart down at the time of change
Old 11-24-2006, 09:44 PM
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
Originally Posted by oups59
Mine doesn't burn any oil.
Ditto.
Old 11-24-2006, 09:54 PM
Normy
Normy's Avatar
Mine does- I go through about 1.5 quarts in 3000 miles. I don't see any blue smoke though. I think I'm leaking from the oil fill tube, and the oil pan gasket.
N!
Old 11-24-2006, 10:50 PM
worf928
worf928's Avatar
Received 1,696 Likes on 1,102 Posts
Both of my GT's burn quite a bit of oil. My GTS less so.
My '91 will go through a quart every 600 miles when I do not drive it every few days. When I drive it several times per week consumption goes down to about 1qt/1000 miles.
The '89 consumes a bit less than the '91.
The GTS consumes a quart about every 1000 miles.
Old 11-24-2006, 11:14 PM
mcholdfast
mcholdfast's Avatar
My 89 GT is less than 1/2 a quart low after a little over 3000 miles since an oil change.
Old 11-24-2006, 11:38 PM
pasa
pasa's Avatar
My 1990 GT burns no oil between changes
Dan 1990 928GT
Old 11-24-2006, 11:48 PM
Shark Attack
Shark Attack's Avatar
No, No oil... Just a lot of money
Old 11-25-2006, 12:10 AM
Wade T
Wade T's Avatar
Mine throws a bit on start up. Haven't seen any change in the dipstick level though. Still won't be statisfied to I do a compression test.
Old 11-25-2006, 02:09 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Mine will throw oil out through the breather system at speeds over 150 MPH, but otherwise burns no measurable amount of oil between annual/10k mile changes.
Old 11-25-2006, 04:44 PM
khalloudy
khalloudy's Avatar
My S4 used oil, about a quart per 1000 miles (and yes i am a leadfoot on it) and it puffed smoke at start sometimes and had all the nasty soot in the exhaust. Once I installed the GTS breather kit, no more oil use and no more smoke at start and no more soot.. Thank God... seriously it was driving me nuts. I do recommend the GTS breather setup. BTW there was a lot of oil ingestion through the breather before, but now it is bone dry
Quick Reply: Does your 928 Burn Oil?
