ATTN KNUCKLEHEADS: Get interior LEDs now!
I've been buying my LEDs from www.superbrightleds.com and www.autolumination.com. #74 bulbs for the pod switches and HVAC control head, 44mm festoon for the shifter "PRND32" on the console, and, iirc, 38mm festoons for the courtesy lights.
I haven't done my clock yet, but I think that's a #74 also.
44mm for most of the interior lights (excl glove box/power outlet etc), 38mm won't work - 42mm might just if you snug up the springs (just get 44mm)
Also get the versions with 9 or 10 individual LED's - any less you will likely be wishing for more light. Bear in mind the 'bright white' or 'super white' are like fluorescent light vs incandescent light - you may not like it - it is indeed a sterile look compared to the yellowish stock festoon bulbs... consider yellow as well as red, blue etc LED's.
Alan
Alan
Thanks, Alan, as always.
I've actually started another thread, "Using LED bulbs in the 928 (fitments, size, etc.)" in the hopes that we can collect as much info as possible in one place: https://rennlist.com/forums/928-forum/312635-using-led-bulbs-in-the-928-fitments-size-etc.html. I didn't think that anyone searching for LED info would think to query "ATTN KNUCKLEHEADS" !!
Cottage Industry Sponsor
Here is something I just learned... Apparently the 78 and 79 models don't have the lights in the doors, as we have them on the later models. So they only have three instead of five interior lights.
I now have an interior light kit for these older models that contains only 3 instead of five LED bulbs, at a lesser cost.
Click here for the interior LED section on my website
Originally Posted by SharkSkin
Nicole. where would the third light be -- glovebox?
Most autoparts stores sell Blule leds that will fit. You may have to bend the contacts slightly. I did all mine for under $20 total! Put a 6" blue led up in each foot well as well for ambient lighting. I also bought two packs of individual blue leds (3 in each pack) and drilled them under the door sill plates to light up the clear "928". Pic's not as impressive as seeing them in a dark parkinglot.
With all blue leds and the EL Glow gauges in blue, it really sets the mood..too bad the back seat's so small.
