Short belt and new bearings for engine driven fan
#31
EDIT: I think I figured it out. The front bearing has no retainer ring. The extended hub (or spacer) limits how far the bearing can migrate along the shaft.
#32
And if a 4L210 belt seems too tight and a 4L220 seems too loose then check the interwebs and get a 4L215. That's what I needed to do for my 1980 Euro S.
I strongly suggest that if you can't get the bolts into the holes easily, without prying or tools, then get a longer belt.
BTW- the belt is a "4L" and a "3L" is too skinny and goes deep into the pulley "V". I suppose one could make that work, but getting the just right belt is better.
#33
Here in Europe you can buy an complete set from Garage de Loods in the Netherlands. Some of the products has Roger too I think.
Manuals with option Code M319 have a smaller pulley
Assembled
Top loose, try 13*1050 mm
Assembled
