86 shark: interior instrument lights are indecisive.
My interior instrument lights either work perfectly (with dimmer working perfectly), or do not (driving pitch black). Sound like a switch? already checked the fuse: no unusual issues/corrosion.
I'm up for suggestions.
That little dimmer can go on the fritz; what's it? A potentiometer? Anyway, I'm sure you've tried the dimmer wiggle? I gave mine a spritz of contact cleaner, and it seems to work consistently now.
Does the dimmer potentiometer operate smoothly... meaning do the lights go from bright to dim without blacking out as you move the dial? Could just be a flakey dimmer.
Not sure if it's very "widespread" but the potentiometer can wear out or corode over time. I cleaned the contacts up at first and it worked for a while, then I ended up replacing and it worked like a champ. In the end, I scrapped it and ended up going with LEDs. Looks soooooo much better now!
