'84 Euro vacuum routing help
Can someone check something for me? I have attached a diagram of the engine vacuum lines for my '84 Euro and where they are routed. I attempted to install the new kit from Mark Robinson, but his diagram and lines do not match at all what my car has. I want to be sure my PO did not F with the routings, so I need someone to check their '84 Euro to see if what I have is correct or if what Mark has is correct.
Hi Mike,
On my 85 euro, the vacuum lines are correct in that everything works but it is also unique in that it has stuff i have not seen on any other car. It is also an auto. I have 2 little rabbit ear shaped plastic pieces that screw into the pass. side cam cover with vac lines attached.
The car is all cocooned, its raining, .......
Long story short, I am not ignoring you, but I don't think I can be of much help.
I've had an '85 euro + the US-spec'd items: the vacuum diagrams in the manuals are virtually identical: where are you having questions??
BTW: no more vacuum kits: parts are just way too hard to find at this point: though I do have plenty of plug wire parts in stock for all colors.
Mark
Mark
