Where to get fender scoops (air intakes)
I should note that I'm trying to create a little more room upfront, so I'd like to be able to ditch the ATF cooler up there. I'm hoping to have the MAF snorkel pop right over the top of the radiator. I'm looking to lower the radiator a couple inches to accomodate a Vette type snorkel and possibly use the factory airbox tray mounted inverted in the high pressure area there.
Originally Posted by atb
Tony,
Do you have an ATF temp sensor mounted anyhwere?
Im still trying to figure the most ideal spot for it. I would think in the pan near the pick up so you know what temp is going INTO the tranny as apoosed to whats going out (damage would be done already)
