Dry Sump Question
Originally Posted by stuartph
Alex
If the pump is mounted where the aircon pump used to be, do you think the aircon belt drive could be used off the crank pulley ?
Alex
So its a new crank pulley then with teeth added
Very very nice!
The pump HAS to be below the pan right?
Then I may have missed something. Whats the problem with putting it where the air pump goes?
thats the pic i was referring to with my bum description of 'wider' than the aircon pulley - i was meaning wider north-south rather than diameter! in the pic above nothing is removed from the standard crank pulley, the new toothed pulley is slipped over the end and both are bolted up to the crank/harmonic damper.
That is the Kelly Moss 928 engine which resides in a 944 GTR. They wanted $15,000 to dry sump my GT; I laughed really hard. Here is another pic:
