Need a Seat Switch for a '87 928
Lets try this again. I'm doing this officially now and have joined the great rennlist community.
I need a used 4-way seat switch (4 arrows on the round button) front-back and up-down motion for a '87 928 automatic.
In the process of fixing it, I broke the round ****. So if possible, all I really need just the **** part
You probably won't find a good used seat switch because it's a ****ty design and they all break where yours did. The "hat" part can't be replaced separately.
Buy a memory seat switch (it's half the cost of the others), and splice in the ends that you need.
There are probably reports of somebody doing a switch replacement with the seat in place, but I think it's almost impossible. The seats come out pretty easily, and the switches themselves aren't too tough.
Under the Lift
Unless you are going to unsolder the old switch from the wire ends and solder in the new one, a neat trick if you can do it (not a lot of slack), you need to remove the seat as the harness is tie-wrapped and some of the plugs are inaccessible.
