Engine idling low w/ lots of vibration on acceleration
Hi,
The other day I took the car for a drive and it ran quite poorly. The idle has dropped to around 400 rpm. When I try any type of acceleration there is a lot of vibration in the steering wheel. I can even see the rear spoiler shaking. But once on the highway at a steady speed you wouldn't know anything is wrong. Oil pressure is good. I'm thinking a loose vacuum hose somewhere but can't find one. I'm not familiar with this engine at all but very much so with the 951. Can someone steer me in the right direction as this has got me down somewhat. I really hope it's something simple...
I had the exact same thing happen after I got the car back from the dealer and I found a leaf next to the maf..sucked everything out and the car ran great...go figure...did the car sense problems the the resistance of the screen of the maf and run on limp mode??
any way something simple..
andy
andy
Captain Obvious
Super User
Super User
Yup, sounds like she’s not running on all 8. I had this happen once. By mistake I mixed up the IAT sensor connector with the last injector on the driver side. Since you don’t drive the S4 that much I’m guessing that one of the injector is probably stuck closed. While the engine is running, try pulling each plug off one at a time. The one that doesn’t make a difference is the cylinder you should start looking into. OR if you have a laser thermometer, lift the car when the engine id cold. Then start it and measure each exhaust port temp. When compared to the others, the one that’s not firing will be really cold.
I hope this helps!
I hope this helps!
It doesn't vibrate at idle, only under acceleration in gear. But the idle is lower then normal. I did try pulling the plug wires to verify if all cylinders are firing but didn't learn much. In my 951 if you pull a plug wire the car idles like total sh*t and that's what I was looking for. But doing the same in this car you barely notice anything. I will try again today and look for even the smallest deviation in the exhaust note. And sorry, no laser thermometer. Thanks for the help guys!
Captain Obvious
Super User
Super User
Could it be in 'limp home' mode?
Do you have any 928-knowledgeable friends that are also practical jokers...maybe they connected the limp home connector? (Or - did you happen to be in the fuse panel area, and connect it up my accident?)
I assume this is your 87? it sounds to me like you are running on 4 cylinders. I had an 89 that did this, the PO had the plug wires on wrong. So i know that engine will run on only 4 cylinders. at itle it sounded fine. Does the 87 have the split egnition system like the 89? if so i would check for spark on all 8 cylinders.... one of your ignition modules, distributors may be toast
I pulled the plug wires today and it seems each cylinder is firing. At least for the moment. Thing is when I was done I took her for a quick spin and she ran fine. So I must have done something by either pulling the plug wires or removing the air cleaner box. Now I have zero in on what it is. I'll play with it some more tomorrow. Like someone mentioned maybe I have an injector that's palying games! :-)
Ok... Today I took her out for a quick 10 minute spin and she ran fine. The low idling and heavy vibration were not there. Then before I put her away it came back. I open the hook just to check things. I noticed a slight whirring type sound coming from the engine. I start poking around and find a hose that is very soft to squeeze.. too soft. Now there are two approx 3/4" hoses coming from under the intake and going into the valve cover on the passenger side. The one towards the front of the car came apart with a good tuck which also showed it had a crack in it and was leaking. Can someone tell me what these are for with maybe some part numbers? Also how big of a job is it to replace them. And please forgive me for my lack of 928 knowledge. Any help is appreciated!
I edited and attached a pic showing the hoses. Not my engine BTW..
ooof. if it is the same one on my 89 the plenum had to come off. and they told me to do everything under there while i had it apart, the total parts cost was $700.00 I think they are just breather hoses but i know mine leaked a lot of oil out of them. good luck. a few pix may help the guys ID what the part is
Administrator - "Tyson"
Originally Posted by bd0nalds0n
Are you sure it's running on all 8 cylinders?
