Old TBs - any alternative uses?
Hoarder that I am I now have 3 old timing belts.
Old A/C, Alt, PS, Airpump belts if not carried in the spare wheel well as spares get used as ties for extension leads, garden hoses etc.
I can't think of anything to use the old TB's for - not much point in carrying a spare one LOL
Suggestions or do I just break the habit of a lifetime and ditch them.
Thank you Thank you Thank you Louis
I knew that there was a good reason for keeping them.
You only need one old belt. You'll have to tear yourself away from the others. I say this laughing because I have two or three old T belts hanging up too. Those are about to be joined by a special T belt that did it's job very well far longer than it should have. My neighbor brought his '89 5 spd over to change oil. It had a strange clicking sound at the front of the engine. I looked down there and saw a timing belt tooth laying by the oil level sender. He shut the engine down immediately. This is what I found after the covers were removed. The no tooth section is about 12" long and the cams are still in time. The engine stopped at 45 deg BTDC, #1 cyl. The car has about 85k miles and the belt was never changed. We also took out the in-tank fuel pump. The hose was split, but not apart. Lucky guy he is.
https://rennlist.com/forums/attachme...d=149029&stc=1
WOW talk about his timing!
I think you saved a near disaster!
Interesting that the car was still in time with a 12" gap in the belt. I guess though that the sprockets must grab more then 12" of the belt at all times anyway. (although actually it dosent look like it does.)
"I had checked it a couple months ago and suggested (for the 17th time) that he had better get the belt replaced."
HA HA HA
Thats so funny, what the hell was he waiting for. does your neighbor not know your a 928 guru!
I cant think of a better neighbor to have. Hopefully he dosent drive the thing and has already ordered up the parts he needs!
HA HA HA
Good save Louis
Do you think he would be interested in 2nd hand TBs LOL both still have the writing on the outside, only 30k on one and 7k but 6 years on the other.
i just realised that saving one for cam timing is probably not valid - i'ld do it with the belt that was already on then replace the belt - buggah.
I used to have a very old but large lathe (wish I still had it) that originally had leather belt drive which I changed to reversed double TB drive - took 4 Tbs from my GM astra cut reversed then superglued back together, could probably get away with one 928TB.
Rest in Peace
I do not see how that engine could have made one more turn.
Actually I do not see how it went that far, that is a lot more teeth than contact the crank gear.
That man needs to buy lotto tickets.
Basic Sponsor
I hang them up like trophys - good discussion point when BSing and drinking beer.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
