New 88 parts car
#31
The Parts Whisperer
Originally Posted by Rob Roy
Wheel make and model?
#32
Mark, the wheels are RH "AG-CUP".
They are either 1 or 2 piece wheels that are meant to look 3 piece.
I think they look good on a 928. Below is a better picture of similar wheels on another car...
Cheers,
Michael
Cheers,
Michael
#35
Team Owner
Heads will fit either side, Stan
#36
What color is the interior? What shape are the rear seat upper halves? If they are blue or black
and nice...dibbs please. Thanks.
Joe Celeste
Tampa Bay, FL
87 S4 Diamante Blau
Joe Celeste
Tampa Bay, FL
87 S4 Diamante Blau
#39
Originally Posted by SharkSkin
#41
928 Collector
Joe Celeste
Tampa Bay, FL
87 S4 Diamante Blau
Joe Celeste
Tampa Bay, FL
87 S4 Diamante Blau
#42
Puff Daddy
WOW!
Mark and his crew are expert vultures!
Flares are aluminum, not steel, not fiberglass, BTW
Yep it was my car
Good none of you guys work in the coroner's office
A LITTLE ADVISE:
When i took the car to the mech. they told me they've seen 4 88's so far woth broken camshafts. I guess is good to check the little triangular piece in front of the camhsafts when doing belt service. If it has hairline cracks, change it right away. Don't let your car die as mine did, it is sad, really sad.
Yep it was my car
A LITTLE ADVISE:
#43
Mine died the exact same way...the triangular piece is what locates the cam gear to the camshaft. It was a very expensive proposition...and in retrospect I should've parted my car too.
#45
The Parts Whisperer
Originally Posted by Barry Johnson
Hey Mark, what head did you give away? I may need a driver's side one if you can help out.
So sad to see these things die
