928 Forum 1978-1995
Sponsored by: 928 Specialists
Missing stud and nut on exhaust manifold
Old 12-05-2008, 04:38 PM
OBehave
Former Vendor
OBehave's Avatar
Originally Posted by s928s
can be done in the car with the right tools. Right angle drill, lefy handed bit and patience. if it is not leaking...leave it alone !!
+1!! If it's not broke,don't fix it! If you have to when you remove the manifold you could also weld a nut to the existing stump of a stud,if ther is one,and when it cools smack it with a hammer and back it right out.If there is no stump or it is broken off flush,you could weld a smaller stud to it and then back it out.Although the latter is a little trickier it is do-able.All 5 928's that I have had the same problem but only 2 leaked and all of them are missing the bracket that Merlin speaks of.
Quick Reply: Missing stud and nut on exhaust manifold
