928 Forum 1978-1995
Sponsored by: 928 Specialists
Tranny Moan
Old Oct 16, 2006 | 06:24 AM
Charley B's Avatar
Charley B
Default Tranny Moan
'88 A/T. Started hearing a moaning sound like a Power steering unit low on fluid, but coming from Tranny area. Actually it sounds more like it is coming from the torque converter when you're right under them. Checked the fluid and added about a quart and 1/4 to bring it up between min and max. Followed procedure with warm engine and moved through all gears before final check of level in neutral. Did not seem to have an effect on the noise. The tranny is performing perfectly so there are no symptems other than the noise. It is present in all gears and is somewhat RPM sensitive. By sensitive I mean it will increase and decrease in volumn as the RPMs change. Anyone want to give me the bad news?
Old Oct 16, 2006 | 09:38 AM
Mark's Avatar
Mark
Do you have LSD/PSD?
Old Oct 16, 2006 | 10:38 AM
ZEUS+'s Avatar
ZEUS+
Possible torque converter flange bearings. No psd in 88.
Old Oct 16, 2006 | 10:46 AM
Roger's Avatar
Roger
Could it be the torque tube bearings? When mine went out, there was a moaning sound present in all gears including neutral and park.
Roger
87s4
Old Oct 16, 2006 | 01:10 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Charley:
If it is all the time, varying with RPM, I vote for TT bearings.
Old Oct 16, 2006 | 06:03 PM
Charley B's Avatar
Charley B
No LSD/PSD. Is there any relatively simple way to isolate it to TT bearings?
Old Oct 16, 2006 | 06:11 PM
JP Rodkey's Avatar
JP Rodkey
Perhaps his dress is too tight?
Old Oct 16, 2006 | 06:13 PM
Charley B's Avatar
Charley B
Roger do you remember if yours sounded like a power steering unit low on fluid?
Old Oct 16, 2006 | 07:35 PM
Jim bailey - 928 International's Avatar
There are six bolts which hold the flex plate to the torque convertor and the convertor bearings are on the flex plate so you still would not know which bearing were bad plus spinning the triangular shaped flex plate seems like a good way to really break things IF it HITS the raised blocks on the convertor. Torque tube bearings make noise and so do convertor bearings which is why we always recommend that the convertor bearings be changed when a rebuilt central tube is being installed.
Old Oct 16, 2006 | 08:01 PM
Charley B's Avatar
Charley B
Lord give me a driveshaft and a coupla u-joints.
Old Oct 17, 2006 | 12:24 AM
Roger's Avatar
Roger
Charley,
It did sound a lot like low fluid in the Ps (when turning the wheel).
It happened little by little, to the point that I didn't notice the difference in sound. I got pulled over for speeding (12 over the limit) and the officer couldn't believe the sound (he actually liked it). He said that HIS shark didn't sound like that.
My mechanic(s) said that the sound was coming from the front torque tube and they were correct.
Roger
87s4
p.s. I didn't get a ticket.
Old Oct 17, 2006 | 12:28 AM
Charley B's Avatar
Charley B
Thanks guys, not much doubt I guess. I wonder how long I can safely drive it that way.
Old Oct 17, 2006 | 12:53 AM
the flyin' scotsman's Avatar
the flyin' scotsman
You started by saying you added a 'quart and a 1/4'. Where did that go? and could that cause your issue?
