4 speed auto trans starting in 1st gear, How do I adjust that?
Jim, check out these threads
https://rennlist.com/forums/928-forum/258342-mb-tranny-part-number.html
https://rennlist.com/forums/928-forum/252809-mb-valve-body-kit-126-270-44-77-a.html
Originally Posted by G Man
Darien. Thanks for the info. I think my trans is in need of some TLC and I am not exactly sure how to go about it. It has always felt like it is a little " off " in the way it shifts. I have done a fluid and filter change with no improvement. I've also done the cable adjustment. You mentioned that you replaced the 2-3 shift valve on you and Tony's sharks. Is this part of some type of shift kit? I found a place online that sells Merc trans parts. They offer some valve body kits for improved shifting. Do you have any experience with these folks? I think I found the trannys that would be in the 928. Check out the link and let me know. I will probably be contacting you for some more info on the 1st gear start mod. Thanks.http://www.bulkpart.com/Merchant2/me..._Code=Mercedes
Jim
Jim
Fleet of Foot
Originally Posted by crackerfeet
no metal in the fluid but it smelled pretty bad (burnt).The PO said he spent 6k on a transmission rebuild and a new torque converter but had no receipts, you can definitely see where the rear end was moved to drop the transmission and a line was cut and spliced back together.
Perhaps a bad thermostat, IRRC the tranny doesnt circulate the fluid to the cooler unless it has too?
I have to do a bit of research on this also as i have yet to mount my tranny temp guage.
How do you know it IS running hot??
My tranny has seen its fair share of abuse since SC'ing. I highly dobut your going to overheat the tranny during your typical 928 driving..even if you are hard on it.
