Converting 82 3 speed to 4 speed auto???
Has anyone updated an early Automatic to a later series 4 speed... was it simple or complex? What parts were needed?
Rick H
Rick H
If it were me I would stick with the three sp trans. I have an 84' with the 4 sp and really don't like the way it works compared to the three sp that was in my 81'. Good luck with the project if you go for it.
When (if) I get the stroker motor done, I'll be seriously considering a 3 speed A/T retrograde in my S4. What am I going to need first gear for anyway? Wonder if I could keep the 2.20 diff?
We blew out two of the three speed transaxles with our 600HP and 600 lbs torque - I was told the 4 speed transaxles as odd as they are with 1st gear are much stronger.
Originally Posted by sublimate
Add a GearVendor and your 3spd becomes a 6spd.
1 Post
Originally Posted by Vilhuer
IIRR '87 and younger 4sp box do not fit into older body without some mods to body on torque converter area.
Originally Posted by pvoth
I like my 3spd tranny.....with a little tweaking it shifts awsome
65 mph in 1st gear and then bam 2nd and it just gets bettter
With the Vacuum Modulator connected. it hangs at WOT and part throttle.
With the VM disconnected, it shifts fast at part throttle, but hangs at WOT.
Adjustment of the VM seems to affect at which RPM it shifts, but not the time it takes to shift.
I updated my 79 to a 4speed.Easy to do and I don't remember having to hit anything with a hammer and the 79 has the large battery box.It will make a huge difference in your 0 to 30 time.You will like it.
Originally Posted by Stan.Shaw@Excell.Net
I have a core torque tube and core transmission available from an '86.5....
