968 pistons needed
Originally Posted by mark kibort
but the 2 valve pistons have to be cut for the 4 valve heads, right? that would be lots of cuts !! 32 of them!! i guess on a 6.5 liter 2 valve project, that would be the way to go.
just looked up some specs. seems that the 968 is the stroker version of the 104 mm 944s2, and also 4 valves.
Mark, 944 S2 and 968 have same 104mm bore, 88mm stroke, 2990cc and 16V head.
2.7L 944 (non S, last year model) has 104mm, 78.9mm, 2681cc and 8V head. This was done to allow factory to get away with just one piston style on non turbo four cylinder blocks. Or was it other way around, 100mm and 88mm.
Anyway. both 944 S4 and 968 pistons are usable.
I saw some 968 pistons the other day outside my work. they were still in the engine though (which was still inside the car). ok... so I guess I didn't really see the pistons themselves, but I assume they were in there
The Parts Whisperer
Originally Posted by Scott M.
A dude on the 951 list (Hosram, or horsham or something like that) had access to a pile of NITB 968 pistons. He was from the middle east IIRC. I'll see if I can dig up the info.
Will 944 S2 pistons work for your application?
That would be great. Yes I can use the S2 piston but I much prefer the 968.
The Parts Whisperer
Originally Posted by Mike Simard
I'm sure I saw a set of 968 pistons on ebay last week but there gone now, does that help?
It does if I can ever get my time machine working.
but, you have to cut valve reliefs on the 944S2 pistons, right? (944S2 is the 3 liter 2valve version)
MK
MK
I guess they might not have as long of a sucess record yet, but aren't there one or more racers sucessfully using Nickasil plated blocks with custom forged pistons? Would that be a more economical way to go? Didn't Adam B. or Tony H. have some future stroker motor pistons laying around at one time? Might be worth checking with them.
The Parts Whisperer
Originally Posted by Larry928GTS
Let me guess. The time machine only needs some 968 pistons to get it going.
I was thinkng 16 valver for 928s. what i should have said is 4 valve or 2 valve per cylinder. doesnt the S2 have 2 valve, not 4 valve per cylinder.
if it is a 2 valve and the 968 is a 4 valve, then the 2 valve pistons would have to be notched for the 4 valve. that was my only question. (point)
confused
mk
confused
mk
Originally Posted by cambria
H-P,
The 944S has 100mm pistons with 4 cutouts.
MK,
both the S2 and 968 are 3.0L with 4valves per cylinder. How many times do we have to say it lol
Why the 968's over the S2? forged vs. cast? I know nothing about modified 928 engines. I've seen Tom's ex-Tilo car at my shop, but that is it
