928 Forum 1978-1995
Sponsored by: 928 Specialists
Ahhh F! I think I f'd my clutch! Warning to 5-speed boostards
Old 10-04-2006, 02:24 PM
  #61
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
He does, and it cannot be heard.............'Course, the cats ARE the mufflers on my car, so I may be hearing impaired.
Old 10-04-2006, 03:03 PM
  #62
FlyingDog
FlyingDog's Avatar
Originally Posted by SMTCapeCod
that doesn't make any sense.
And besides that, I thought the murf systems used a blow off valve.
It makes perfect sense. Blowoff valves are very noisy. Ever hear a high pitched pop or shriek when a turbo car comes off throttle suddenly? They are used as a safety device to avoid catastrophic overboost.
Old 10-04-2006, 03:07 PM
  #63
AO
Supercharged
AO's Avatar
Guys-
Please start a new thread if you want to debate blow-off valves. Thanks.
Old 10-04-2006, 03:09 PM
  #64
FlyingDog
FlyingDog's Avatar
Originally Posted by Andrew Olson
Guys-
Okay Mr. Inadequatesingledisk.
Old 11-09-2006, 10:56 AM
  #65
AO
Supercharged
AO's Avatar
Resolution:
If you didn't see the glazed flywheel and leaky RMS, read this threrad.
Anyway, I installed the Spec Stage 3+ clutch. It barely fits in there, but it did fit. They must have a stock of old release bearings, because the kit came with the old style. Luckily, I had saved my old clutch fork and guide tube.
Initial reaction is that this thing grabs like a [insert favorite metaphor]. They say it is a streetable clutch, but I in my forst 20 miles or so, it isn't that friendly. It's almost impossible to feather the clutch. Maybe becasue the friction disc is so new? ANyway, I'll drive with it for a while and see if I can get used to it.
One thing that is quite different is teh engage/disengage point ont he clutch pedal is very high - almost at the very top of the pedal. I'll look it up later, but does anyone know if this is adjustable?
Overall, I think this will be the ticket to harnessing all that power!
Quick Reply: Ahhh F! I think I f'd my clutch! Warning to 5-speed boostards
