Driving lights
Clean and seal Fogs
I took the time to clean and properly seal my fogs and extra time with anhydrous alcohol poured over the reflectors to prevent any spotting on the surface. This really made a huge difference in brightness. Very rarely do I ever need the main headlights at night even on I-5, except when one moves at/near california's threshold speed for automatic license removal.
I wasted so much money by buying high wattage bulbs for my fogs, because they are useless as supplements to the high beams (h-4) main lights. With the low beams, fogs are useful for what they are meant to do: illuminate the way throught the fog. I have them aimed at the sideof the road since I lived in Carmel wher it can turn from clear to pea soup fog in a blink of an eye. But on the open road and all other times, I keep the fogs off.
Rufus,
Thanks for the post on changing the fogs to 100W H3's. If this works out as expected it will be one of the best tips I've ever gotten here. Very simple, I know, but I never thought of it. For a long time I've been trying to figure out how to do away with the flip up headlights (not delete them, just not have to use them. I have never liked flip ups on any car) I converted this afternoon and will try them out tonight.
Tried them out last night. Big improvement. The passenger side needs to be realigned, but for use on back roads where high speed is not appropriate (we have tons of deer around here) they are just fine. No need for the main driving lights anymore.
Originally Posted by Rufus Sanders
Cool. Hope you lke them. Keep in mind that you can go up or down in wattage. If "Johnny Law" doesn't like it, try 55W ones, but 130W ones are available too. - Ruf
So far I have not had any problem with heat using the 100W H3's. My '79 fogs have glass lenses and even after 1/2 hr driving last night, they were just warm to the touch. As for the current draw, should be about 8 amps.
While aligning I came across another aspect of this issue and that is that the beam pattern of the two fog lights is different. The driver's side acts more like a spot light while the passenger side looks like a flood. This is very clear if you block one light while adjusting the other. ?????
Yes, a bulb not at the focus of the parabola would change the beam pattern. I rather like the spotlight effect though since I'm trying to duplicate the driving lights. The drivers side lens has a part number on it, the passenger side does not?
