928 Forum 1978-1995
Sponsored by: 928 Specialists
16 valve cam lifter seat removal
Old 09-15-2006 | 07:55 PM
Stan.Shaw@Excell.Net's Avatar
Question 16 valve cam lifter seat removal
I am looking for expertise on removing the lifter seats from the cam tower. I also need a lifter seats replacement, so if someone has an extra cam tower available, please let me know.
Old 09-15-2006 | 10:08 PM
mark kibort's Avatar
mark kibort
I have a cam tower available. dont know what side its from, but its in "stored" shape.
its from a euro 82
MK
Old 09-16-2006 | 12:08 AM
Hey MK, Let me know how much. I only need a lifter seat from one now, preferably with the lifter, but I will gladly consider a complete housing.
Old 09-16-2006 | 12:43 AM
GlenL's Avatar
GlenL
Lifter seat? D'ya mean the sleeve or some part I'm missing the pleasure of knowing?
If it's the sleeve, then use a big pliers (channel locks) and gently twist it.
Old 09-16-2006 | 12:50 AM
Lifter sleeve sounds right, where are you going to grab it, it is essentially flush with the face of the cam tower. Sounds like you know though.... help!
Old 09-16-2006 | 01:10 AM
GlenL's Avatar
GlenL
On the early engine, like 78 to early '80, the sleeves are seperate pieces. Sounds like you've got a later 16v engine. Looked to me like the sleeves are pressed in on that version.
What's the issue?
Old 09-16-2006 | 01:18 AM
The cam tower is from an '8o Euro S
The issues is a head socket bolt had an hex tool break in it, so to get it out a window was cut in the side. To properly clean the housing, removing the cam seems prudent. It seems the sleeves need to be removed to let the cam slide out.
I also found a sleeve is scored, so want to replace that one. Alternatively I can just put the cam in a different housing.
So I need at least a lifter sleeve and possibly a cam housing.
I also need to know how to remove the sleeve. I suspected they might be pressed in, so am looking for confirmation.
Old 09-16-2006 | 03:28 AM
mark kibort
Didnt know there were sleeves in the cam tower, looked like one solid machined piece. Ill pull it out of the shed and see how it looks . no lifters are in there, but it may be salvagable. everything from the euro stuff worked well, i see no reason why the towers wouldnt work. actually, i think this is the bad one, that had a crack on one of the mounting flanges. Ill let you know tomorrow.
MK
Old 09-16-2006 | 09:55 AM
I didn't know there were sleeves, until we tried to pull the cam out and they were in the way. Your cam tower may be just what I need, something to pull parts from. Hopefully it will come with an attractive price, particularly if it is damaged
Quick Reply: 16 valve cam lifter seat removal
