Rear Cam Seals!
Rear Cam Seals!
Does anyone have some tips on how to remove the rear cam seals?! Not much room, have the updated tapered type and having a hell of a time getting them in.
Dan Gates
Frisco, Tx
85S manual
Dan Gates
Frisco, Tx
85S manual
Dan,
I did mine a few years ago. It is tight but can be done. I used some wood blocks and then pried them in with a screwdriver wedged between firewall and wood block, the wood block against the new seals. I coated them with super lube so that would slide in a little easier. I think I got one or two from under the car, had a little more room reaching up from there. 3 years and no leaks!
