This thing is huge!!! (just picked up my 928)
You didn't say whether it was auto or manual or whether the oil is black or red. If it is red (and it's an auto) you need to fix that right away (ask me how I know) water in the auto fluid is very bad news.
Originally Posted by Jim bailey - 928 International
Ah the 928 is 72.28 Inches wide a HONDA Accord is 71.6Inches wide ! 500SEL 1986 is 79 inches wide
N!
Rocket Pilot
With my old 930 and 928 parked in the garage , side by side, The 930 seemed bulkier. I think it is driving feel rather than actual size. My 928 seems small in parking lots compared to most cars. And next to my sisters' 98 trans am, it is downright tiny.
Originally Posted by MGW-Fla
Concrats & Welcome! Sounds like you have a realistic, optimistic & appreciative attitude about it... hopefully your love & enjoyment of owning a shark will cause you to always look at it that way.
944 is 68.3 inch wide ... The heat exchanger inside the radiator is not available as a replacement part so it would need either a good used radiator or possibly our all aluminum higher capacity new radiator for $895. Make sure that it is NOT auto trans fluid in the water because if coolant water gets into an automatic transmission it does BAD things very quickly. The heat exchangers first leak oil or atf into the coolant since the pressures are much higher but after the engine is shut down the coolant holds residual pressure long after shut down until it cools down.
Originally Posted by JHowell37
Oddly enough, most of the electrical stuff seems to work just fine. But you know what the bottom line is? It's mine. It's paid for (although some would say I haven't yet begun to pay.) And it's a 928.
Hoorayy!!!!!!!!!!!!!
Congrats on your good luck!
Sounds like you got yourself quite a project car there - you're officially in the club.
I do have one important request...
PLEASE POST SOME PICS!
Congrats and good luck. Sounds like you are where I was a year and a half ago. (except some of my electrics didn't work) One thing I've learned about these cars is that everything can be fixed. The parts are available and technical help is just a click away.
Let us know when EVERYTHING works.
The 928 looks bigger than it is until you park it next to something else. I park mine next to my 944 and it doesn't seem much larger yet when I go to pull the 944 in the garage and work on it there is so much more room for me to manuver around the 944.
If you park a 928 next to a 996 they look to be very close in size.
that's what she said... I thought that at first too. It's an optical allusion. That car fits in my garage and i can still pull my caravan in BEHIND it.....
the car shrinks as you get used to it. take it to a track day, and get a flying start to driving it.
(I'm on a business trip right now, and miss my 928, I'll have to give it a good spanking when I get home)
mm
mm
Road Warrior
yours shrinks after you spank it?? hmmmm.... mine usually needs more spanking. maybe you need a master... er, mechanic?
sounds like deja vu - mine only needed a few fixes too. 10 yrs and god knows how much $$$ - it just needs a few fixes but I wouldn't sleep w/another car in my garage.
