928 Forum 1978-1995
Sponsored by: 928 Specialists
Any thoughts on using Penzoil 15w40?
Old 08-25-2006 | 05:07 PM
  #31
fabric's Avatar
fabric
Originally Posted by anonymousagain
Chris - you're referencing the Multi-grade chart, not the Synth chart
Consider that it ISN'T on the Synth chart, because there's more flow/better oiling from the lower 5w/10w weight and the 50 higher/hot number is still covered...essentially the Engineer is saying, "Why not get better flow (especially cold/startup) with the same hot 50 weight coverage".
Don't get me wrong, 15w-50 M1 - great oil, although IMHO a 5w makes more sense for cold/startup coverage.
yes, all good points. Next time it's time to change I'll be going with the 5w50, but surprisingly it's very rarely below 20F here, at least close to the lake where I usually am.
Old 08-25-2006 | 07:00 PM
  #32
anonymousagain's Avatar
anonymousagain
IIRC, Mr. Hillary clarified not too long ago that a quality 40w Synth (eg, RotellaT 5w-40) has the same hot viscosity as a 50w (eg, M1 15w-50) at ~200deg normal oil operating temp...not sure how much hotter it'd need to get before a 50w is beneficial, or even if it could ever get there
[FWIW - Walmart <by me at least> carries RotellaT 5w-40 Synth for $16/gal and I've had good pressure and temps even on 100deg days with AC. I would never have tried it if Mr. Hillary hadn't pointed it out as a "best of". Anyway, it seems like a bargain compared to M1 @ nearly $7/qt.]
Old 08-26-2006 | 01:10 AM
  #33
JKJ308's Avatar
JKJ308
So what About the Synth. Blend 15w40 PENNZOIL?
Quick Reply: Any thoughts on using Penzoil 15w40?
