freaking Euro dash lights... what do they say?
79 euro model... I have two lights on the dash, they say something but what i have no idea?, they are located on the same side as the oil pressure and voltage gauge. one is above the 2 gauges and the other is below the two gauges... one says hand??????? somthing or other and the other has
"???breams????? " soemthing or other.....
1st one says, "Slow down, approaching warp speed"
2nd one says "You are holding up traffic, use pedel on right"
Hope this helps.
Hope this helps.
Brems = Brakes
There are different brake warnings, brake lining [Bremsbelag], brake fluid level [Bremsfluessigkeit] or brake circuit [Bremskreis] (unequal pressure in the circuits)
Other lights:
Handbremse: hand brake
Oelstand: oil level
Other lights:
Oelstand: oil level
Originally Posted by FRporscheman
Rich beat me to it.
Your 928 didn't come with a courtesy female German translator?
There was a thread like this a while ago that helped. Most of my lights, I figured out a while ago, but I'll be damned if I can remember them now. The one your describing sounds like handbrake/emergency brake?
The handbrake switch on thoose old euro's ( like mine), is mounted on a small metal tap, right under the brakehandle. I could be bended, and thus also be bended back in place or defect ! And "bremsbelag" is the brakepad sensor, often not connected or/and faulty wirering somewhere between pad and "computer". Mine is on all the time - but now I don't bother anymore. My other 928 had it too. On that car, I found the wire that generated power to that control light ( under the footrest ) and simply cut it off......
