928 Forum 1978-1995
Sponsored by: 928 Specialists
90 vs 88 head
Old Jul 30, 2006 | 09:47 AM
Rod Underwood's Avatar
Rod Underwood
Default 90 vs 88 head
Is an 88 head the same as a 90? 928 International doesn't list the 88 head fitting a 90, but they don't list anything for a 90.
Rod
Old Jul 30, 2006 | 10:03 AM
John Veninger's Avatar
John Veninger
The head from the 1990 is a "better" head. The main change was the casting thickness was increased near a few bolt holes that were starting to show cracking in the old design.
The 1990 head is a direct replacement, but you'll need a couple of longer head bolts.
Edit-I see you want to put the head 88 head on the 90. You can, but you'll need a few shorter bolts. Depending upon the damage to the 90 head, it may be better to fix than replace with the earlier head.
Old Jul 30, 2006 | 10:10 AM
Rod Underwood
Thanks, that's exactly what I wanted to know.
Rod
Old Jul 30, 2006 | 05:17 PM
bd0nalds0n's Avatar
bd0nalds0n
When my '88 S4 heads were exchanged for rebuilt units, the rebuilt units I got WERE CRACKED at the bosses where the head bolts mount.
I would encourage you to stick with the thicker bosses of the GT heads and would discourage you from using earlier S4 heads.
You probably won't have any problems, but IMO it's relatively cheap insurance. It's a big job to swap heads.
