I NEED MORE BILL BALL BURNOUT TYPE VIDEOS!!
Under the Lift
You need Quicktime, linked in the sig as well. I don't like Quicktime, but from the source files, it was the only video converter that would render a good image that was reasonably compact. Also, the links might be dead if my host is down (it happens), but if the small animated GIF burnout appears in the sig, the other files should be available.
H2
Under the Lift
H2:
Rolling start with no prep or funny struff at all. Surprised me too. With the AT torque multiplier effect down low and the Jag/Eaton, the torque figures below 3K RPM are much higher than what I report in my sig for peak torque. Also, I don't have limited slip.
