928 Forum 1978-1995
Sponsored by: 928 Specialists
bulb chart
Old Jul 21, 2006 | 12:50 AM
Oldtee's Avatar
Oldtee
Default bulb chart
My 'D' lamp on the instrument panel is out and I cannot find something that gives me a light blub number. Are they Porsche only or do they take something like a 337? Pet was no help, SM even less so.
Old Jul 21, 2006 | 02:35 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Yeah, we should give a reward to someone who finds a decent bulb chart. What you need is Porsche 999.631.027.90. It should be equivalent to Sylvania 2721 or Jahn 1601. Double check that.
Old Jul 21, 2006 | 08:12 PM
Oldtee's Avatar
Oldtee
Thanks, it seems this should be easier.
Old Jul 21, 2006 | 09:37 PM
6.0-928S's Avatar
6.0-928S
There is a bulb chart in the 928 Int'l catalog. Used to be one in the old Automotion catalog as well.
Hammer
Old Jul 21, 2006 | 09:45 PM
whitefox's Avatar
whitefox
Bill, the 928 int'l catalog says the part number is: 999.631.301.90 "Instrument bulb with holder"
Old Jul 21, 2006 | 11:06 PM
aircooler's Avatar
aircooler
Hammer,
Well????
How is the progress?
Any pics?
Cheers,
Michael
Old Jul 22, 2006 | 02:03 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
I think I linked the bulb w/o the holder, but he needs to check it. Best just to order from one of our 928 vendors and be done with it.
Old Jul 22, 2006 | 05:32 AM
John Speake's Avatar
John Speake
The "D" bulb and others that reside in the tach are wire ended, solder in. So they don't have a holder...
Old Jul 22, 2006 | 06:29 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Thanks, John. I've never had mine out and was passing information on the bulb numbers and equivalents based on a search.
Old Jul 22, 2006 | 10:13 AM
Oldtee's Avatar
Oldtee
Some of 'dis don't compute.
For a 85 (auto not specified) it lists 19 PN 999-631-301-90(item 8) and 4 PN 928-641-893-00(item 21). It would seem that P,N,R,D,3,2 = 6 lights which (and this is a leap) I presume are the same bulb type unless they are part of the 19. Is a PN 999-631-301-90 the same as the 999-631-027-90 mentioned above in Mr. ***** post?
Old Jul 22, 2006 | 01:06 PM
John Speake
I doubt very much of these wire ended bulbs are shown on any Porsche P/N list. They are very much "intefrated" into the tach assembly.
I had to remove the dash, remove the tach, tach off the needle etc to repalce the bulbs. The bulbs I used were T1 3mm dia 12v 60mA, wire ended.
Some people have managed this repair without taking the pointer/dial off. Do a search here on Rennlist.
You may find it advisable to repalce the most commonly used gear lamps at the same time - I had to do the job twice in a few weeks. Also, be careful of debris falling into the lens area.
Old Jul 22, 2006 | 01:22 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
OK, I should have stayed out of this. I got the PN for shift indicator bulb for 89-95. WRONG!
As John indicated, these bulbs are soldered in and not directly available.
http://www.nichols.nu/tip600.htm
Old Jul 22, 2006 | 03:44 PM
Oldtee's Avatar
Oldtee
Originally Posted by Bill Ball
OK, I should have stayed out of this. I got the PN for shift indicator bulb for 89-95. WRONG.
As John indicated, these bulbs are soldered in and not directly avalaible.
I missed the Nichols write up. Did not think to look under Automatic Transmission. Bill, U did good, thanks. It is hard to know everything about every year but you came through. I guess I'll just have to live with "knowing" I'm in D.
Old Jul 22, 2006 | 06:53 PM
John Speake
THe other gotcha that can make the system not illuminate bulbs correctly is the alignment of the gear selector mecahnism on the side of the auto 'box. There is a proceedure for lining this up in the workshop manual.
Old Jul 22, 2006 | 07:44 PM
Oldtee's Avatar
Oldtee
Probably not the problem. I had the instrument panel out to fix (or so I thought) the speedometer. More likely jiggling the thing when I took the speedometer out of the cluster caused it to burp. Good thought tho!
