Cam gear - cool idea
I saw this in the Off Topic forum.
It would be neat if this could be adapted to our cam gears to set the timing... Not sure if it can or not.. still a cool idea.
The Parts Whisperer
I did a simpler version of this concept years ago. I had my machinest cut several keyways with different offsets. It was a little more difficult to adjust that the one shown in your picture but it was simpler, cheaper and possibly stronger with less possibilites of failure.
Administrator - "Tyson"
Ok, probably the dumbest question of the day here:
How is this any different than rotating the gear one or two teeth over? Or is the idea to find tune timing inbetween gear / belt teeth? Or just an easier way to adjust cam timing without removing the belt?
It is my understanding that one tooth is too much. Something like 7.5 degrees. I have also read on here that this might even cause valve interference on a 32 valver.
Mike
1987 S4 Auto
Mike
1987 S4 Auto
The Parts Whisperer
Originally Posted by GlenL
Search for "Offset Woodruf key." Available in several steps and at about $7.
Originally Posted by mark anderson
I looked into those first but they kinda scared me because of the loss of material.
Do 944 cam gears not fit 928s? Lindsey Racing has adjustable cam gears for 944s.
Inventor
Cam bolt friction is what holds the cam gears in place. The key pretty much only gives you a reference point.
On o fthe companies- unorthodox racing, I think, once had plans for 928 units but last time I touched base with them they had canned the project due to lack of market...this is some time ago when exhaust mods were the wild frontier of ownership....
By the way, a 427 Ford is an interference motor! Ask me what I think of offset keys!
Hammer
