Highest recorded HP for a NA 4.7, 5.0 2 valver
Guys what is the highest recorded dyno run at the wheels for these cars? I'm going to start dynoing my 2 valve soon to tune it, it has already had one base line run on a Dyno dynamics machine and showed that it was running an AFR of 10 to 1.
I don't know what the spark was doing but I think there is more there. I think that once this engine is tuned I will get a good idea of what the 5.9 liter engine will produce as this current engine as it is only slightly modified.
Thanks in advance
Greg.
Thanks in advance
Greg.
ok greg, we are waiting to hear what your baseline dyno was... honestly you have more patience than me if you can resist posting the numbers untill you have optimised tuning, come on, lets see your dyno!
1 Post
Hi
BEFORE ...my Nitrous..I have a dyno chart with 284 RWHP ....on my 16 valve 4.7....if it helps..
On my next dyno run....im expecting between 400 and 450 RWHP....WITH Nitrous....
All the best Brett
928 S2 AUTO V8 4.7 LTR 1986 IRIS METALLIC BLUE WITH X-PIPES ,RMB ,PROMAX CHIPS, KICKDOWN SWITCH.K&N.NITROUS KIT 150 HP.
PCGB UK 928 FORUM MODERATOR - Email managingdirector@pchealthcare.co.uk
All the best Brett
Very Good Brett! I have read a page that someone had posted somewhere that listed many many 928 dyno results. I do not know where it is as it was some time ago.
IIRC there was a euro on that list with 315 rwhp and i think it only had headers and not a hybrid. I also thought it was tested or worked on by devek. I could be wrong though. But I would take Brett's result any day.
Interesting...I just put a 4.7 Euro engine with L-Jet injection and 84 US cams together for forced induction. I figure the baseline on this NA engine to be about 270 HP (crank) give or take. It should take well to boost.
