5-sp Transmission Snik-snik
I've got a Q for the 5 speed crowd. When my 5-sp tranny is cool it seems to shift better than when warm.
I've gone on some spirited runs and when warm, find down-shifting to be a pain. I have to wiggle and push with a lot of force to get the gear change; a real negative when preparing to come out of a corner. I've got the clutch pushed in and am off the throttle. Up-shifting and a throttle mash works well.
Cheers,
John Fagerlund
'89 GT (gotta love it)
Cheers,
John Fagerlund
That is definitely the reverse of normal (not just 928s, but any manual tranny). When was the last time the tranny had an oil change? Many have had success with switching to Redline 75W90NS (or a mixture of NS and non-NS for LSD) in 928 trannies with shifting problems.
FWIW, not long after I got my GT, I replaced the transaxle fluid with Mobil 1 gear oil (assuming that was the right thing to do). Seemed to work fine for a while, but eventually started having grinding issues, mainly on downshifts. I thought the synchros were going.
Finally changed the gear oil again, but this time with Redline and it was a NOTICEABLE difference!! Very smooth shifts, both up and down.
Gear oil was changed when I pulled the tranny to replace the seals. That was about 20k miles ago. I'll try the Redline approach, and since I have the belly pans off and am going under this weekend, I'll bleed the clutch again. I'll even try burping the master cylinder this time.
When warm, I tried pumping the clutch pedal to see if the shifting was smoother, but no joy. With that, I assumed the clutch was ok; but with these beasts, you never know.
Thanks,
John Fagerlund
'89GT (running like a top and shifting like an old truck)
Thanks,
John Fagerlund
Redpathtribe, I have Mobil 1 in my GTs rear end and I've noticed the same grinding problem during DE events toward the end of my 20 minute run. At first I thought it was me getting careless but I realized it was the tranny fluid getting too hot. Need to change...
Rest in Peace
I had similar problems wit my 89 GT, especially after the short shifter swap. I used to be a M1 believer but switched to royal purple which made a discernable difference.
Supercharged
Originally Posted by hinchcliffe
Somebody have a link to 5-spd tranny fluid change? I did the rear diff with Amsoil last year but never did the tranny. What's the procedure?
"Drain. Fill. Done."
Yeah, what he said!
I used the royal purple stuff too. And added a short shifter at the same time. I may try going back to the original GT short shifter.
I don't have any grinding, just hard to get into gear.
Cheers,
-j
Yeah, what he said!
Cheers,
-j
OK, so I guess when I changed my diff fluid it also cahnged the tranny fluid. I was think they may be separate.
