928 Forum 1978-1995
Sponsored by: 928 Specialists
LH Parts Needed
Old Jun 27, 2006 | 09:09 AM
Mattman928's Avatar
Mattman928
Default LH Parts Needed
Does anyone have a damaged LH for a newer GT as well as the wiring harness? That they are throwing away?
Actually all I need is the Wiring harness plug with about 1 foot of wires on it. And I would like an intact LH brain connector (The circuit board can be damaged, I only want the connector on the front of the brain itself with intact pin connectors on the back.
I am building an experimental Engine monitoring system and need to make a test rig
Thanks,
- Matt
Old Jun 27, 2006 | 10:42 AM
MBMB's Avatar
MBMB
Matt,
Somewhere I have an LH brain from a Volvo or summat (same connector as 928) for a similar project. I'll see if I have an extra if you don't have one once my garage is done (soon soon). I also found a source for new harness plugs.
We brainstormed this idea on the 'list a couple of years ago. Some folks had good ideas.
