upgrade to m28/11?
Hi all,
my car is running very well at the moment, engine rebuilt, brakes new etc. etc. Basically every moving part on my car is either new or rebuilt. And everything is strictly original. Cosmetically my car is nice, but not perfect. Several repaints, and minor body repair over the years, and panel gaps aren't perfect.
Let's say I get my filthy hands on an M28/11 engine. That is the 300hp cis euro engine. And the S brakes. I aslo have (access to) s4 front and rear spoilers.
What do I do?
The '81 euro non-S (my car) is the lightest 928 ever, and would scream with a 300hp engine, and track days tell me I could use bigger brakes too.
But then again "if it works, don't fix it".
Please advice...
MM
What do I do?
Please advice...
MM
Then, you just take the short block and heads and bolt it all to your US intake system. (kind of a waste, as running the Ljet US stuff with a euro bottom end is like running a 50% restrictor plate in racing!)
so, if you get a euro, you need the 84 and newer euro intake runners, plennum and throttle body too. then, you are all set. (one minor mod, re-routing the cold start circuit from going to the heads to going to the plennum via one of the additional euro ports you can use on the plennum, which is very easy to do)
Mk
Mk
Originally Posted by gruffalo
Hi all,
What do I do?
Please advice...
MM
What do I do?
Please advice...
MM
Mark: if I get this engine, it will be a complete m28/11 unit. I will not open it, or swap any parts at all. It will be a direct fit into my car that has the m28/09 today.
that will be nice.
I forgot the Ljet didnt happen until 82, so you are safe. great upgrade. bolt on 50hp!
Mk.
Mk.
that will be nice.
Mk.
Mk.
upgrade!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Administrator - "Tyson"
How much is this upgrade going to run you? Might be cheaper / easier to bolt on a blower.
Not to mention all the bits and pieces that is nice to have...
Sounds like a good deal for both of us if we get the car for a fair price!
Ian
FYI - if you're swapping the suspension / brakes, then WYIT, I recommend that
you go to S4.
I had an 84 (S) and a 79. I swapped in S4 suspension and brakes on all 4 corners
of the 79. At this point, the stopping power was noticibly better than the S.
BTW - this swap also required using S4 half-shafts.
I sold the S and still have the 79.
Like any project, what you put in ($) will be directly proportional to what you get
out (
you go to S4.
out (
