Engine noise....calling all 928 sleuths *6-22-06 update with pics*
#61
928 Engine Re-Re-Rebuild Specialist
Originally Posted by Stan.Shaw@Excell.Net
I just pulled a driver's side tensioner today, prior to pulling the cams, so I would say "yes".
I'm not looking forward to pulling that cam cover. The holes for one of the bolts only has a few threads left. I still remember shouting expletives trying to get a wrench on some of the lower cam cover bolts.
#62
Yeah, it is much easier with the motor on an engine stand.
I just pulled the cam cover. Not much under there to go amiss and make light metal noises. The chain tensioner and the lifters are all that come to mind. Maybe something is blocking the oil flow to that area?
#63
Stan...do you have a guess about what that sound is? When I did the rebuild, I replaced the chains, but left the tensioners and pads alone since they looked fine. Everything was thoroughly cleaned.
All the gaskets (valve cover and plug) are new (less than 4K miles) so I'm hoping I don't need to replace them after pulling off the cover.
#64
My guess is because of the constant frequency, perhaps the chain is running over bare metal not on the pads. I would think it will be obvious once the cover is pulled.
I would think if you are careful you can reuse the gaskets.
#65
I probably ought to order the pads now if I have any chance of taking my beast to the company car show on Friday. Maybe the local P-dealer stocks them (yeah, right).
#66
Captain Obvious
Super User
Super User
I would take the vavle covers off first before ordering any parts. Who knows, maybe you'll need more than the tensioner pads.
From all the posts, I bet it's either the tesioner getting weak or the pads are worn.
#67
Supercharged
#68
Originally Posted by Andrew Olson
Actually, there's a place in Royal Oak that surprisingly has a lot of parts in stock for our cars. There is a $50 order minimum. It's called All European. #248-399-9211. Prices are in-line with big 3 and no shipping (but you do pay tax). You will need to provide them the part numbers.
#69
#71
Call Mark H-
He's got an entire spare car over in Ann Arbor.
His willingness to go pick up my car in Dayton is more than I could ever ask!
#75
Originally Posted by Bill Ball
Looks a bit chewed up.
